Showing results forĀ
Search instead forĀ
Did you mean:Ā
Switch SG350XG-24F Flash Memory
sirising
switch reboot after get  log  How to fix this problem ?
2147483644 2024-Feb-09 00:13:49 Emergency %DNS_CLIENT-F-SRCADDRFAIL: Result is 2. Failed to identify address for specified name 'time-c.timefreq.bldrdoc.gov.', requested addr type 1. ***** FATAL ERRO R ***** Reporting Task: DNSC. Software Version: 2.5.9.16 (date Feb 27 2023 time 16:53:52) base_address=0x004a5000 ros(+0x798c98)[0xc3dc98] ros(HOSTG_fatal _error+0x14)[0xc41130] ros(OSSYSG_fatal_error+0x258)[0x1154370] ros(+0xaa1cb8)[0xf46cb8] ros(+0x7fc540)[0xca1540] ros(+0x7fc68c)[0xca168c] ros(+0x7fc9dc)[0 xca19dc] ros(+0x7ffdc4)[0xca4dc4] ros(+0x80180c)[0xca680c] /lib/libp2linux.so.1(task_run+0xf4)[0xb6e9c840] ***** END OF FATAL ERROR *****
2147483645 2024-Feb-09 00:08:12 Emergency %DNS_CLIENT-F-SRCADDRFAIL: Result is 2. Failed to identify address for specified name 'time-c.timefreq.bldrdoc.gov.', requested addr type 1. ***** FATAL ERRO R ***** Reporting Task: DNSC. Software Version: 2.5.9.16 (date Feb 27 2023 time 16:53:52) base_address=0x004d0000 ros(+0x798c98)[0xc68c98] ros(HOSTG_fatal _error+0x14)[0xc6c130] ros(OSSYSG_fatal_error+0x258)[0x117f370] ros(+0xaa1cb8)[0xf71cb8] ros(+0x7fc540)[0xccc540] ros(+0x7fc68c)[0xccc68c] ros(+0x7fc9dc)[0 xccc9dc] ros(+0x7ffdc4)[0xccfdc4] ros(+0x80180c)[0xcd180c] /lib/libp2linux.so.1(task_run+0xf4)[0xb6edb840] ***** END OF FATAL ERROR *****
2147483646 2024-Feb-04 03:46:19 Emergency %DNS_CLIENT-F-SRCADDRFAIL: Result is 2. Failed to identify address for specified name 'time-a.timefreq.bldrdoc.gov.', requested addr type 1. ***** FATAL ERRO R ***** Reporting Task: DNSC. Software Version: 2.5.9.16 (date Feb 27 2023 time 16:53:52) base_address=0x0042d000 ros(+0x798c98)[0xbc5c98] ros(HOSTG_fatal _error+0x14)[0xbc9130] ros(OSSYSG_fatal_error+0x258)[0x10dc370] ros(+0xaa1cb8)[0xececb8] ros(+0x7fc540)[0xc29540] ros(+0x7fc68c)[0xc2968c] ros(+0x7fc9dc)[0 xc299dc] ros(+0x7ffdc4)[0xc2cdc4] ros(+0x80180c)[0xc2e80c] /lib/libp2linux.so.1(task_run+0xf4)[0xb6f50840] ***** END OF FATAL ERROR *****
sirising
