Switch SM-ES3G-16-P issue
Hi dear engineers.
I have a cisco3945e router with SPE slot SM-ES3G-16-P swith module connected.
SM-ES3G-16-P switch has 18 gigabit ethernet ports (2 uplink and 16 external).
Two uplink gigabit ethernet ports of the Switch are connected to the Router inside of  the Router case.
External 16 ports  are also gigabit ethernet ports.
It mean that if  rate of each external port is more than 125 Mb/sec then total  rate of all 16  ports is more than 2Gb/sec and Switch can't  forward  traffic rapidly, which  become a cause of some issues.
Question: Can I in some way to increase a bandwidth of two internal ports
                  by software, IOS commands or making  some change in hardware, like
                  replace gigabit  to 10 gigabit????????
I cannot use twinging connectors to make faster (10Gb), beacause Switch SM-ES3G-16-P is a slot of my c3945e router
Please see jpeg file below
Thanks in advance
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Actually, a 3945E is recommend (by Cisco) for up to 350 Mbps of WAN (i.e. duplex) bandwidth, so it's questionable whether it could even well support the dual gig of internal bandwidth to the switch module.
This discussion has been reposted from Additional Communities to the LAN, Switching and Routing community.
