Switch Stack Problem
mdorostkar
Community Member
Hello
There are 3 3750G-24TS and 1 3750G-24TS-S1U switches. I stack the switches but the result of the "show switch neighbor" shows that cable between switch 1 port 1 and switch 4 port 2 is down. stack is not full,  I have tested all of the ports and all of the cables. the IOSs are the same on all switches.
what can I do ?
Hello
Are they cabled up correctly?
example:
sw1 p1 - sw2p2
sw2 p1 - sw3 p2
sw3 p1 - sw4 p2
sw4 p1 - sw1 p2
sh stack
res
paul
Sent from Cisco Technical Support Android App
Kind Regards
Paul
Thanks for your help
yes I cabled them correctly
here is sh stack command result
today one of the switches (3750G-24TS-S1U) restarts randomly
so i removed it from the stack
SW-ED-01#show stack
Minimum process stacks:
Free/Size   Name
5040/6000   hulc_flash init
5768/6000   CDP BLOB
8536/9000   IP Background
10400/12000  master cfg mgr init process
5728/6000   vqpc_shim_create_addr_tbl
5712/6000   SPAN Subsystem
5712/6000   bulk config process
5760/6000   hpm bulk_vlan_state process
9376/12000  Init
5712/6000   stp_change_tree_type
8760/9000   cdp init process
5704/6000   HUDLD fiber table process
5560/6000   RADIUS INITCONFIG
5704/6000   Hulc Backup Interface Process
35176/36000  TCP Command
2600/3000   Rom Random Update Process
8096/12000  Virtual Exec
5552/6000   MDFS LC IPC Init Process
Interrupt level stacks:
Level    Called Unused/Size  Name
  4  3879339046   8096/9000  NETWORK INTERFACE CHIP
  5           0   9000/9000  SUPERVISOR EXCEPTIONS
  6      194556   8936/9000  NS16550 VECTOR
Leo Laohoo
Post the output to the command "sh switch details".
