ā02-18-2025 07:52 AM
We have a stack of 5 9200 48p-E switches that show a port fault on Port 1 on 3/5 of the switches in a stack after checking the cables they seem fine what are the chances of a bigger problem with the ports themselves
ā02-18-2025 08:37 AM
- Do you have more details on the port fault , such as logs
or is there a visual indicator (e.g.) ?
M.
ā02-18-2025 09:18 AM
You can check
#test cable-diagnos tdr int x/x - after checking you can check result this / #show cable-diagnostics tdr int x/x' will provide the TDR results.
Thanks!
ā02-18-2025 04:05 PM
What is the firmware version?
What is the uptime of the switch?
