Switch Stack with different firmware
mvarazlic
I am trying to upgrade the firmware on a switch stack.  I have used network assistant to do it.  The upgrade failed and now the stack is running two different versions of firmware:
Switch Ports Model SW Version SW Image Mode
* 1 56 WS-C3850-48P 03.06.06E cat3k_caa-universalk9 INSTALL
2 56 WS-C3850-48P 03.06.03E cat3k_caa-universalk9 INSTALL
3 56 WS-C3850-48P 03.06.03E cat3k_caa-universalk9 INSTALL
I am not sure how to remedy this.  The firmware has copied to the flash of all three switches but only one of them with boot with the newer ios.
Mark Malone
If the files are in flash ready to go in each switch as .bin try this below save it and then reload the stack
boot system switch all flash:.......(image.bin)
or is it tar files
they are there as .pkg files.
Leo Laohoo
Use the CLI command because it performs better (compared to CNA).
Post the complete output to the command "dir flash-1:".
