switch stack.
ilnaiduccna
Hi Experts,
I have to stack 4 switches in my organization that all switches have different vlans
Firends can anybody explain what are the steps, commands I have to do.
Naidu.
saro
What model switches are you stacking? If 3750s with stack cables, they will look like one switch. YOu don't have to do anything special. If it's a 3550/3560 do this:
- Set all switches to VTP mode transparent
vtp mode transparent
- Set all switches vtp domain name so that it is not NULL
vtp domain MYVTP
- Create vlans on all switches
vlan 100
vlan 101
vlan 102
The ports that connect to one another should look like this:
interface GigabitEthernet0/1
switchport mode trunk
spanning-tree portfast disable
The user ports of the switch should look like this:
interface GigabitEthernet0/7
switchport host
! this is a script that does a few commands
switchport access vlan 100
This is just a bare minimum configs, but it should get the 4 talking to one another. If your switch is a completely different model, post that here. That will help.
