Switch static entry with auto-learn
Mary Leon
Frequent Visitor
Frequent Visitor
Hello, everyone,
I'm using Packet Tracer 7.3.1. I'm trying to to add a static entry but with auto-learn option in a switch 2950-24. Unfortunately, the command does not work:
switch0(config)#mac address-table static 0040.45B6.BD87 vlan 1 interface Fa0/2 auto-learn
% Invalid input detected at '^' marker.
However, without auto-learn the command does work fine.
What am I doing wrong?
Thank you in advance.
Martin L
nothing is wrong; some commands will not work or are not available in PT or behavior is not the same as in real device
PT from Cisco Net Academy is just a software Simulator; it does not run on real IOS or virtual IOS; It is close to IOS but It does not really behave like real IOS would (some simply features do).
PT is excellent tool to learn and practice networking fundamentals and commands for CCNA exam.
Regards, ML
**Please Rate All Helpful Responses **
Martin L
Regards, ML
