Switch username/password problem
jasonww04
Level 5
Level 5
Can someone please tell me why the attched config gives me only a Password: prompt when I SSH to it? It originally had a password on line vty 0 4.
Reza Sharifi
Under the vty lines add login local:
line vty 0 4
exec-timeout 0 0
login local
transport input ssh
And test again.
Reza Sharifi
line vty 0 4
exec-timeout 0 0
login local
transport input ssh
And test again.
I use AAA and login authentication admin under line vty 0 4 on all my routers and have never run into this problem. I'll try login local and let you know what happens.
This just keeps getting better. The only option for the login command is authentication. No local.
OMFG I'm an idiot. The reason I wasn't getting a username prompt when using SSH to get to the switch is because I was coming from a router. The switch was using the router's username so I just needed to supply the password.
