Switch Utilisation
RashikaBatra
Visitor
How to decide whether a switch is being fully utilized or not?
18 Replies 18
balaji.bandi
Not sure what context based here :
is this port utilisation - you can vide show interface status | in connected
CPU - show process cpu
show interface x/x port utilisation
or get some NMS tools to monitor switch using SNMP
BB
Basically need to find out which nexus switch being fully utilized and which switch is not being fully utilized.
Can you define what is fully utlised ?
as long as the interface and process, ram not fully utlised, the switch operating as expected.
you can do health check :
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus9000/sw/6-x/system_management/configuration/guide/b_Cisco_Nexus_9000_Series_NX-OS_System_Management_Configuration_Guide/sm_11gold.html
BB
Basically need to check whether a switch is being utilized as expected by normal utilization percentages ,for example normal CPU Utilization is 80 or 90 percent out of 100 that way I want to check whether the switch overall (not only CPU) is being utilized to normal level of utilization or not .
You need NMS for this - get install NMS your choice to monitor the device to get archieve monitoring details.
BB
Can you suggest any software for this ?
Many Like below : ( good NMS you get plenty)
example :
libreNMS / Zabixx
PRTG / Solarwinds
BB
Is there any other way other then NMS to do the same as I am unable to install NMS on my system ?
Has the port been used for the last, say, 90 days or not?
How to check this ?
I use tools like AKIPS to check how many days ports have not been used.
Is it a kind of NMS only ?
please see my opinion below
