switch with 24 SFP ports ?
michal.karnik
I like the SG-300 switches for SMB and I'd like use them in our network. Design is quite simple just 6 SG-300 switches connected to one central switch using SFP ports (using 2 port trunks) so I need 12 SFP ports and this is my question. Could you recomend me switch with more then 12 SFP ports from Cisco for this SMB network ? I don't know all the Cisco product lines and I can't find it.
Thank you M.
Reza Sharifi
If you need more the 12 Port SFP you can use this one:
Stackable 24 GE SFP Ethernet ports, with 350W AC power supply
1 RU, IP Base feature set
WS-C3750X-24S-S
There are switches available with 12 and 24 SFP ports are below..
Cisco Catalyst 3750X-12S-E 12 Gig SFP ports with 350W power supply WS-C3750X-12S-E
Cisco Catalyst 3750X-24S-E 24 Gig SFP ports with 350W power supply
Please rate the helpfull posts.
Naidu.
