01-21-2014 02:47 AM - edited 03-07-2019 05:42 PM
I have 2 switch 370 in stack. Random the switch is operational, but is impossible connect to switch in ssh or telnet
01-21-2014 05:39 AM
What type of error are you getting, while trying to telnet or ssh ? Can you post the output?
Chandu
01-21-2014 05:47 AM
I have configured switch to log information message to syslog, but there isn't message of error. When i try to connect to switch i receive connestion refused. I try to analyze the switch with nmap but there isn't open port tcp on 22 or 23. The switch is operational but for my is impossible establish a connection.
01-21-2014 05:52 AM
Are you getting like the below one?
Chandu
01-21-2014 05:57 AM
My answer is :
sfwus01p:/var/lib/tftpboot# telnet 192.168.0.17
Trying 192.168.0.17...
telnet: Unable to connect to remote host: Connection refused
The only solution is reboot hardware (unplugged electrical cable and plugged electrical cable). I think to upgrade my IOS version, if there isn't none solution.
01-21-2014 06:09 AM
Can you post a ping and traceroute to the device your tyring to telnet ...from
sfwus01p:/var/lib/tftpboot# ?
Chandu
01-21-2014 06:12 AM
sfwus01p:/var/lib/tftpboot# ping 192.168.0.17
PING 192.168.0.17 (192.168.0.17) 56(84) bytes of data.
64 bytes from 192.168.0.17: icmp_seq=1 ttl=255 time=0.479 ms
64 bytes from 192.168.0.17: icmp_seq=2 ttl=255 time=0.472 ms
64 bytes from 192.168.0.17: icmp_seq=3 ttl=255 time=2.21 ms
64 bytes from 192.168.0.17: icmp_seq=4 ttl=255 time=9.60 ms
^C
--- 192.168.0.17 ping statistics ---
4 packets transmitted, 4 received, 0% packet loss, time 3003ms
rtt min/avg/max/mdev = 0.472/3.193/9.609/3.771 ms
sfwus01p:/var/lib/tftpboot# traceroute 192.168.0.17
traceroute to 192.168.0.17 (192.168.0.17), 30 hops max, 40 byte packets
1 192.168.0.17 (192.168.0.17) 0.516 ms * *
01-21-2014 06:16 AM
As you mentioned, if you have these already configured, you might be hitting a cosmetic bug. What is the IOS version your are running? I would try to upload a new one on the stack and see if that resolves the issue.
01-21-2014 06:13 AM
Walter, Please can we have a loo at your switch configs? Would it be possible for your paste it here if you have old one handy or if you could console and get it for us. I seems like you dont have telnet or SSH configured on the boxes.
Cheers,
-amit singh
01-21-2014 06:35 AM
The version of Cisco IOS is 12.2(44) SE.Here my configuration for authentication :
aaa new-model
aaa authentication login default local group tacacs+ none
aaa authentication login Console local enable
aaa authorization exec default local group tacacs+
aaa authorization commands 15 default local group tacacs+
aaa authorization commands 15 Console if-authenticated
aaa accounting commands 15 default start-stop group tacacs+
aaa accounting network default start-stop group tacacs+
aaa accounting connection default start-stop group tacacs+
aaa accounting system default start-stop group tacacs+
tacacs-server host 172.16.0.5 key 7
tacacs-server host 172.16.0.6 key 7
tacacs-server host 172.16.0.7 key 7
tacacs-server directed-request
line con 0
password 7
line vty 0 4
transport preferred ssh
line vty 5 15
01-21-2014 02:47 PM
Ok, console into the switch. Post the following command outputs:
1. sh version;
2. sh proc cpu | ex 0.00
01-22-2014 08:34 AM
It's strange. If i connected the console to switch 2 the message is "Low memory" and i can't connect. If i connected the console to switch 1 there isn't message, but i don't have a prompt for login. The switch are monitored by mrtg and mrtg visualize the following data :
Max | Average | Current | |
Used | 77.0 MRAM (30.1%) | 77.0 MRAM (30.1%) | 77.0 MRAM (30.1%) |
Free | 2093.3 kRAM (0.8%) | 2080.4 kRAM (0.8%) | 2081.3 kRAM (0.8%) |
01-22-2014 02:50 PM
Forget it. This information is more than what I need.
What IOS are you running? When you console into an appliance and you're greeted with "Low memory" this is an indication that the IOS you're using is or has a CPU/Memory hog bug.
01-23-2014 12:31 AM
The version of IOS is 12.2(44)SE. I search on Internet if there is a memory upgrade for 3750, but the memory upgrade for switch start by 4000/4500 series. This stack is connected by 2 uplink to another stack switch of 3750 and by 2 uplink to another stack switch of 3750 (Total i have 3 stack switch of 3750 configured in spanning-tree environment). Also the another stack of 3750 switch has the same issue (after many week of switch up and running, i can't connect to the switch with telnet or ssh, i think for the same problem, low memory).All the stack switch have the same version of IOS.
The spannig-tree is configured in rapid-pvst mode with one stack primary for some vlan and another stack secondary for some vlan.
For now i can't upgrade IOS version of switches, which are the alternative solutions ?
02-04-2014 03:23 AM
Upgrade the IOS of your entire stack. Go to 12.2(55)SE8 as it's more stable than what you are currently using. It's more stable by A MILE!
