Switch
abdulkarim041
Level 5
Level 5
hi All,
We have a switch at client side. Client compliant that switch was not being accessed. When I visited the site and connected my consol with switch then I founded the following error as:
Unexpected exception to CPUvector 0, PC = 201CAB8
: Unexpected exception to CPUvector 0, PC = 201CAB8
After restarting the switch issue has been resolved. I just want to know the cause of the error
BR
Abdul Karim
Reza Sharifi
Not sure what type of switch you have.  Here is a link an IOS bug.  This may not be exactly the same issue as yours, but it is good idea to contact TAC for support.
https://quickview.cloudapps.cisco.com/quickview/bug/CSCee43883
Thanks Reza,
Kindly find the show version as
Cisco IOS Software, C3560E Software (C3560E-UNIVERSALK9-M), Version 15.0(2)SE9, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2015 by Cisco Systems, Inc.
Compiled Tue 01-Dec-15 06:42 by prod_rel_team
ROM: Bootstrap program is C3560E boot loader
BOOTLDR: C3560E Boot Loader (C3560X-HBOOT-M) Version 12.2(58r)SE1, RELEASE SOFTWARE (fc1)
LAN-PWI5-AS-01 uptime is 6 days, 2 hours, 3 minutes
System restarted at 05:42:08 UTC Thu Apr 28 2016
System image file is "flash:c3560e-universalk9-mz.150-2.SE9.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
License Level: ipservices
License Type: Permanent
Next reload license Level: ipservices
cisco WS-C3560X-24 (PowerPC405) processor (revision K0) with 262144K bytes of memory.
Processor board ID FDO1841R2GL
Last reset from power-on
2 Virtual Ethernet interfaces
1 FastEthernet interface
28 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : A0:EC:F9:09:7D:80
Motherboard assembly number : 73-12554-11
Motherboard serial number : FDO184120TN
Model revision number : K0
Motherboard revision number : B0
Model number : WS-C3560X-24T-E
Daughterboard assembly number : 800-32786-02
Daughterboard serial number : FDO18411A18
System serial number : FDO1841R2GL
Top Assembly Part Number : 800-31331-09
Top Assembly Revision Number : E0
Version ID : V06
CLEI Code Number : CMMPW00DRA
Hardware Board Revision Number : 0x05
Switch Ports Model SW Version SW Image
* 1 30 WS-C3560X-24 15.0(2)SE9 C3560E-UNIVERSALK9-M
Configuration register is 0xF
Thanks for the output.
Can't find any reference to this error message.  I think you should consult TAC so they can investigate the issue.
