Switch
897271415
A switch is configured with V LAN s 10, 20, 30. Which of the following commands will remove only V LAN 30 from that switch?
A:Switch(config-if)# no switch port access v LAN 30
B:Switch# delete flash :v LANDAT
C:Switch(config)# no v LAN 30
D:Switch(config)# no v LAN
E:Switch(config-if)# no switch port trunk allowed v LAN 30
answer C is correct:
