Switches 3850 and 3750 on Cisco Packet Tracer
Mathi
Hello everyone,
I'm quite new with PT,
I'm a student in some Audiovisual School, and i'm in charge of the network part.
I'm trying to make my Audiovisual school's network Topology on PT, but i got a few problems.
We are using Layer 3 Switches as Cisco 3850 and Cisco 3750, but they're not available in PT, do you know a way to emulate them or upload them to my PT ? Is it possible to stack them ? Also, we have a 24 port layer 2 switch with 2 Fiber ports, (we're on two different networks so we needs at least 24 ports). The only switches with Fiber on PT have 10 ports... Do you have an idea for this ? And last question (i'm really beginning, maybe this is all obvious...) how can with have two fast ethernet ports on PC ? My only solution is to use Server to emulate a two fast ethernet ports PC.
Thank you for your help, i'm kind of stuck...
(I'm really sorry for my english, i'm a french student... Please have pity...)
Mathi
Martin L
PT has 24-port c3650 switch (the one with dual-power supplies). you can add 4 fiber optic SFPs in there; you probably did not see it as you must scroll picture to the right. Drag Fiber or 1000Base-T SFP.
Yes, server box in PT also supports dual IPs and fiber module port.
No, there is no switch stacking in PT.
Leo Laohoo
Move this thread into the Cisco Learning Network.
Martin L
Thank you very much for your answer !
I'll use only server and c3650 switch to build my network then.
Thank you again,
Good evening
Mathi
