10-01-2013 02:39 AM - last edited on 03-25-2019 04:26 PM by ciscomoderator
Hi Everyone,
I'm currently configuring switches mentioned in the title and need some advice on the conifguration. The network consists of two core switches (Catalyst 3560X 24) and three access switches (Catalyst 2960S 48). Core switch 1 is the gateway for all devices on the network. There are two vlans: 340 for data traffic and 341 for voice traffic. Core switch 1 will host servers from vlan 340 and core switch 2 from vlan 341. There is one DHCP server for both vlans as configured in the vlan interfaces however there are two different gateways for those same vlans. My question is whether the ip helper-address and ip route commands are used correctly.
Best regards,
Marcin
CORE SWITCH 1
CoreSwitch1#show conf
Using 6338 out of 524288 bytes
version 12.2
no service pad
service password-encryption
hostname CoreSwitch1
boot-start-marker
boot-end-marker
enable secret 5 ****
username admin privilege 15 secret 5 ****
no aaa new-model
system mtu routing 1500
ip routing
ip domain-name antenna.cisco
crypto pki trustpoint TP-self-signed-3930416384
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3930416384
revocation-check none
rsakeypair TP-self-signed-3930416384
crypto pki certificate chain TP-self-signed-3930416384
certificate self-signed 01 nvram:IOS-Self-Sig#3435.cer
spanning-tree mode rapid-pvst
spanning-tree vlan 340 priority 24576
spanning-tree vlan 341 priority 28672
vlan internal allocation policy ascending
ip ssh time-out 60
ip ssh authentication-retries 2
interface Port-channel1
switchport trunk native vlan 340
switchport mode trunk
interface Port-channel2
interface Port-channel3
interface Port-channel22
interface FastEthernet0
no ip address
no ip route-cache cef
no ip route-cache
no ip mroute-cache
interface GigabitEthernet0/1
switchport access vlan 340
switchport mode access
spanning-tree portfast
interface GigabitEthernet0/14
interface GigabitEthernet0/15
description LINK_TO_CORE_SWITCH_2
speed 1000
duplex full
channel-group 22 mode desirable
interface GigabitEthernet0/16
speed 1000
duplex full
interface GigabitEthernet0/17
speed 1000
duplex full
interface GigabitEthernet0/18
speed 1000
duplex full
interface GigabitEthernet0/19
description LINK_TO_ACCESS_SWITCH_3
speed 1000
duplex full
channel-group 3 mode desirable
interface GigabitEthernet0/20
speed 1000
duplex full
interface GigabitEthernet0/21
description LINK_TO_ACCESS_SWITCH_2
speed 1000
duplex full
channel-group 2 mode desirable
interface GigabitEthernet0/22
speed 1000
duplex full
interface GigabitEthernet0/23
description LINK_TO_ACCESS_SWITCH_1
speed 1000
duplex full
channel-group 1 mode desirable
interface GigabitEthernet0/24
speed 1000
duplex full
interface GigabitEthernet1/1
interface GigabitEthernet1/2
interface GigabitEthernet1/3
interface GigabitEthernet1/4
interface TenGigabitEthernet1/1
interface TenGigabitEthernet1/2
interface Vlan1
no ip address
no ip mroute-cache
interface Vlan340
ip address 172.16.34.1 255.255.255.0
ip helper-address 172.16.34.25
no ip mroute-cache
interface Vlan341
ip address 172.16.35.1 255.255.255.0
no ip mroute-cache
ip classless
ip route 0.0.0.0 0.0.0.0 172.16.35.252
ip route 0.0.0.0 0.0.0.0 172.16.34.21
ip http server
ip http secure-server
banner login ^C
This is a restricted system
No unauthorised access allowed
^C
line con 0
password 7 ****
logging synchronous
login local
line vty 0 4
password 7 ****
logging synchronous
login local
transport input ssh
line vty 5 15
password 7 ****
logging synchronous
login local
transport input ssh
end
CORE SWITCH 2
CoreSwitch2#show conf
Using 6247 out of 524288 bytes
version 12.2
no service pad
hostname CoreSwitch2
boot-start-marker
boot-end-marker
no aaa new-model
ip routing
ip domain-name antenna.local
spanning-tree vlan 340 priority 28672
spanning-tree vlan 341 priority 24576
ip ssh time-out 60
interface Port-channel11
no ip address
no ip route-cache
no ip mroute-cache
shutdown
switchport access vlan 341
description LINK_TO_CORE_SWITCH_1
speed 1000
duplex full
channel-group 11 mode desirable
speed 1000
duplex full
speed 1000
duplex full
speed 1000
duplex full
speed 1000
duplex full
speed 1000
duplex full
speed 1000
duplex full
speed 1000
duplex full
speed 1000
duplex full
speed 1000
duplex full
interface Vlan1
no ip address
no ip mroute-cache
shutdown
interface Vlan340
ip address 172.16.34.2 255.255.255.0
no ip mroute-cache
interface Vlan341
ip address 172.16.35.2 255.255.255.0
no ip mroute-cache
ip classless
ip http server
banner login ^C
^C
line con 0
password 7 ****
logging synchronous
login local
line vty 0 4
password 7 ****
logging synchronous
login local
transport input ssh
line vty 5 15
password 7 ****
logging synchronous
login local
transport input ssh
end
CoreSwitch2#
ACCESS SWITCH 1
AccessSwitch1#show conf
Using 10196 out of 524288 bytes
version 12.2
no service pad
hostname AccessSwitch1
boot-start-marker
boot-end-marker
no aaa new-model
switch 1 provision ws-c2960s-48lps-l
crypto pki trustpoint TP-self-signed-59782272
subject-name cn=IOS-Self-Signed-Certificate-59782272
rsakeypair TP-self-signed-59782272
crypto pki certificate chain TP-self-signed-59782272
certificate self-signed 01 nvram:IOS-Self-Sig#3233.cer
ip ssh time-out 60
no ip address
shutdown
interface GigabitEthernet1/0/1
switchport voice vlan 341
interface GigabitEthernet1/0/44
interface GigabitEthernet1/0/45
speed 1000
duplex full
interface GigabitEthernet1/0/46
speed 1000
duplex full
interface GigabitEthernet1/0/47
speed 1000
duplex full
interface GigabitEthernet1/0/48
speed 1000
duplex full
interface GigabitEthernet1/0/49
interface GigabitEthernet1/0/50
interface GigabitEthernet1/0/51
interface GigabitEthernet1/0/52
interface Vlan1
no ip address
shutdown
interface Vlan340
ip address 172.16.34.3 255.255.255.0
no ip route-cache
interface Vlan341
ip address 172.16.35.3 255.255.255.0
no ip route-cache
ip http server
banner login ^C
^C
line con 0
password 7 ****
logging synchronous
login local
line vty 0 4
password 7 ****
logging synchronous
login local
transport input ssh
line vty 5 15
password 7 ****
logging synchronous
login local
transport input ssh
end
10-01-2013 05:26 AM
Your DHCP config is correct, however you don't need 2 default routes, you just need one.
Also, are you planning to manage your devices via vlan 340 or 341? It is usually a good practice to have a separate vlan for management and not use your data or voice vlan. If you decide to add a management vlan, change the default route to use that subnet.
10-01-2013 05:35 AM
Hi Reza Sharifi,
Thank you for prompt reply.
I've just realized I didn't explain the whole situation with default routes well enough.
The reason I added two default routes is because traffic from devices on the vlan 340 (172.16.34.0) will have their default gateway set to Core Switch 1 (172.16.34.1) and then the traffic needs to be redirected to a gateway with IP address of 172.16.34.21.
As for the vlan 341 (172.16.35.0) the default gateway for the devices will be Core Switch 1 as well but with the vlan 341 address. (172.16.35.1). Then the traffic needs to go to 172.16.35.252.
If I leave only one default route as specified how will the switch know to redirect traffic for vlan 340 to the ip address 172.16.34.21 ?
I hope I didn't make it too confusing.
Best regards,
Marcin
