Switches Connection
UnivoiceLLC
Can a 3750E Cisco switch be connected to a 3750 using fiber? and what is required to have this done.
Julio E. Moisa
Hi Fernando,
Yes you can, basically you need to use the same SFP model on both devices.
This link can be useful to know the proper SFP supported:
http://www.cisco.com/c/en/us/td/docs/interfaces_modules/transceiver_modules/compatibility/matrix/GE_Tx_Matrix.html
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Thank you Julio.
Hi Fernando,
You are welcome, you can use the TwinGig module, to use 1G:
http://www.cisco.com/c/en/us/products/collateral/switches/catalyst-3750-e-series-switches/product_data_sheet0900aecd805bbee3.html
Is there any modules that you can recommend?
