Switches High Latency using PING
helios999
We have a problem in our network I assume there is a device that causes a loopback or has a defective network interface. How can I check the status of our network and nodes in our 3560 Switch?
Can somebody help me what commands to use?
John
iyde
Level 4
Level 4
Hi.
Some more details about your problem would be helpful.
What do you mean by the headline "Switches High Latency using PING" ?
Show log, show spantree etc. would be helpful commands for you in torubleshooting, but again, a more clear description of why you assume what you assume will be of help.
