Switches loop
NORBERTO RIVERAE
Community Member
Hi, I have a new fiber connection to close my network, but when I tray to connect my Build 3 switch with my Build 2 switch, it does a loop and I need to unplug the fiber, this is the configuration on that ports
Build 2, WS-C4503 switch
interface GigabitEthernet1/2
 switchport mode trunk
 speed nonegotiate
 spanning-tree portfast disable
Build 3, WS-C3560G-48TS-S
interface GigabitEthernet0/50
 speed nonegotiate
I attahced a diagram ilustrated the new conection between build 2 and build 3.
I hope you can help me with my configuration
Leo Laohoo
Ummmm ... You really are not providing much information.  From the diagram, the 3560CG has another link going to another switch (upper right-hand corner and down to another one above your 4503).  So I really can't make any comment until we know what the config of those two boxes are.
If you are so much concerned about the loop, which rightly you should, then you may have to consider temporarily disabling one of the two links.
Hi Leo
This are the fiber ports configuration from the build 3 switch (WS-C3560)
1.- To core switch upper right corner (WS-C4506)
     interface GigabitEthernet0/49
2.- Same rack WS-C3560, under yellow circle
     interface GigabitEthernet0/51
3.- To production area in build 3 (WS-C3560) left lower corner
     interface GigabitEthernet0/52
4.- This is the port that I want to connect to build 2 Ws-C4503, but does a loop
       speed nonegotiate
The configuration from the core switch (WS-C4506) to Build 3 are:
interface GigabitEthernet2/5
And there is the configuration from Build 2 WS-C4503 that has a loop
 speed nonegotiate
The other port from Build 2 that connect to other WS-C4503 are
  interface GigabitEthernet1/1
I Attached partial LAN diagram with connections descriptions
You know what I noticed about your interface configuration?  You've allowed ALL VLANs across.
Exactly what VLANs are you trying to traverse from Office Plant #3 to Office Plant #2 (and back)?  If you really want, you can configure allowed-vlan on the interface.
Hi Leo
I will tray this on weekend, only that I have time to test it, and does not affect production, I will tell you about the results
