12-02-2013 04:39 AM - edited 03-07-2019 04:52 PM
we are looking into replacing an old Cisco 2950 Switch by a new model that should support NetFlow and the ability to use Fast Ethernet Single Mode SFPs (GLC-FE-100LX). Is there a model offered by Cisco that can be used with this configuration? At first I thought a WS-C3560X-24T-S with the C3KX-SM-10G Service Module could work but unfortunately it seems that the service module only supports GbE SFPs.
If not, could we use a router instead and use it as switch only? Actually the only thing we want achive is to use aquire netflow statistics for our uplink port to the Internet.
Michael
12-02-2013 08:38 AM
The 2960-X supports sampled NetFlow and lists single mode fiber support on this page:
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps12995/data_sheet_c78-728232.html
12-03-2013 01:40 AM
Thank you, but the 2960-X only seems to support the GLC-GE-100FX which is multi mode fiber:
We also need full NetFlow since we need to account traffic, as to my understanding sampled NetFlow cannot be used for that since not everything is captured.
12-03-2013 02:21 AM
Cisco 3750 supports GLC-GE-100FX but to my knowledge netflow is not supported. Would suggest to use Cisco-4500 which would meet your requirements.
Sathvik K V
12-03-2013 02:42 AM
Hi Sathvik,
thank you, I think the Cisco 4500 is too expensive for us. Do you know if it is possible to somehow throttle a GbE SFP to 100mbps? We are currently using a dark fibre to our ISP where the fibre teminates on a 100mbps SX SFP. In our buliding we use a media converter that converts from fibre to copper. We now don't want to use the media converter anymore and therefore need a switch that allows us to connect the fibre directly, which as to my understanding is only possible if we use a 100mbps SX SFP as well. Unfortunately most switches don't seem to support 100mbps SX SFPs and NetFlow together.
Michael
