- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
01-19-2014 01:07 AM - edited 03-07-2019 05:39 PM
Can someone please help me on my quelry: why encapsulation is not required in layer 2 and why it is required on Layer 3.What woud be the imapct of that ?
Thanks in advance.
Solved! Go to Solution.
- Labels:
Other Switching
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
01-19-2014 01:41 PM
I think you are talking about inter-VLAN communications using routing. Read the document below as it will answer a lot of your questions.
Configuring InterVLAN Routing and ISL/802.1Q Trunking on a Catalyst 2900XL/3500XL/2950 Switch Using an External Router
http://www.cisco.com/en/US/tech/tk389/tk815/technologies_configuration_example09186a00800949fd.shtml
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
01-19-2014 04:59 PM
Leo provides a link with good information. But the question from the original poster seems to indicate a fundamental misunderstanding about encapsulation and I would like to respond to that part.
Encapsulation is a fundamental concept in the development of the layered model and in the implementation of the TCP/IP stack. The original question seems to assume that encapsulation happens at one layer or the other. But the reality is that encapsulation happens multiple times at multiple layers. The original data payload is produced in the application that is running. The original data payload is encapsulated at the data link layer, where the addressing in the encapsulation is based on the protocol port numbers. Then encapsulation happens again at the networking layer where the addressing in the encapsulation is based on IP addresses. Then encapsulation happens again at the data link layer where the addressing in the encapsulation is based on MAC addresses (assuming that the data link layer is using Ethernet).
encapsulation is important at each of these layers and if it did not happen at a particular layer then our ability to forward the data would be impacted in a negative way.
Rick
Rick
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
01-19-2014 01:41 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
01-19-2014 04:59 PM
Rick
Rick
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
01-19-2014 09:50 PM
Thanks Leo and Richard,
You were right Richard, i was bit confused in encapsulation tagging.Now i got my answer.
Ruchik Sharma
