Switching From Nexus3k to ASA Access Port Issues.
SJValley
All,
I have a nexus 3k  acting as LAYER2 only and it is directly connected to an ASA routed mode with Subinterfaces. All my ports that are configured and trunk ports send traffic properly, but my interface that is configured as an access port is not.  any help would be appreciated.
Example Config
Host not able to pass traffic
interface Ethernet1/2
description Serverx
switchport access vlan 255
Host able to pass traffic
interface Ethernet1/3
speed 1000
description "DEVOPS_ESXI.10_Prod"
switchport mode dot1q-tunnel
switchport trunk native vlan 255
UOPLINK TO ASA
interface Ethernet1/47
speed 1000
description "connect to site"
ASA
interface GigabitEthernet0/5.2
vlan 255
nameif DEV_Prod
security-level 50
ip address 10.254.255.129 255.255.255.128
Reza Sharifi
Is there a specific reason for this command?
shouldn't the port be just trunked
switchport mode trunk
Also,
if the native vlan is 255 and not default vlan 1, the same command should be configured across all devices.
