08-23-2011 01:12 AM - edited 03-07-2019 01:50 AM
Hi there,
I have a stack "A" of 2 3750X newly installed having data vlan and a voice vlan. Just for temporary usage, we had connected a 3750 standalone switch "B" on the port G1/0/27 of the stack.
B was programmed to be an access port carrying just the Data vlan. Switch A's port was also prgrammed the same.
But whats happening is that local users on the stack cannot ping their own data vlan gateway which locally on the stack switch. Whereas the users in the same vlan but on the standaone switch can reach this gateway.
Ports Config on the stack:
Switch_A#sh run | begin GigabitEthernet1/0/25
interface GigabitEthernet1/0/25
description ***** Standard Interface configuration to Client PC & Phone *****
switchport access vlan 240
switchport trunk native vlan 240
switchport mode access
switchport voice vlan 651
no logging event link-status
speed 1000
duplex full
srr-queue bandwidth share 10 10 60 20
srr-queue bandwidth shape 10 0 0 0
queue-set 2
priority-queue out
no snmp trap link-status
mls qos trust cos
auto qos voip trust
no mdix auto
flowcontrol receive on
spanning-tree portfast
service-policy input PM-SET-DSCP
interface GigabitEthernet1/0/26
queue-set 2
priority-queue out
mls qos trust cos
auto qos voip trust
no mdix auto
interface GigabitEthernet1/0/27
description ***** Temporary Uplink*****
queue-set 2
priority-queue out
mls qos trust cos
auto qos voip trust
no mdix auto
I tried doing debug on arp frames and could see the following:
000612: Aug 23 15:07:34.809 WST: IPARP_TRACK: ARP tableid(0) 10.42.64.43 Vlan240 mode(1) modified.
000613: Aug 23 15:07:46.771 WST: IPARP_TRACK: ARP tableid(0) 10.42.64.43 Vlan240 mode(1) modified.
000614: Aug 23 15:07:49.799 WST: IPARP_TRACK: ARP tableid(0) 10.42.64.43 Vlan240 mode(1) modified.
000615: Aug 23 15:07:55.830 WST: IPARP_TRACK: ARP tableid(0) 10.42.64.43 Vlan240 mode(1) modified.
000616: Aug 23 15:08:03.120 WST: IPARP_TRACK: ARP tableid(0) 10.42.64.43 Vlan240 mode(1) modified.
000617: Aug 23 15:08:04.328 WST: IPARP_TRACK: ARP tableid(0) 10.42.64.43 Vlan240 mode(1) modified.
000618: Aug 23 15:08:06.089 WST: IPARP_TRACK: ARP tableid(0) 10.42.64.43 Vlan240 mode(1) modified.
000619: Aug 23 15:08:06.291 WST: IPARP_TRACK: ARP tableid(0) 10.42.64.43 Vlan240 mode(1) modified.
000620: Aug 23 15:08:07.314 WST: IPARP_TRACK: ARP tableid(0) 10.42.64.43 Vlan240 mode(1) modified.
Any suggestions?
08-24-2011 05:29 AM
Do you have an ARP entry for the users who can't ping? Are you seeing their MAC address in the CAM? You may want to clean up the configs and remove the trunk configurations on the ports if you are going to make them access + voice vlan.
Cheers,
Fabienne
09-22-2011 06:35 PM
Hi Fabienne
I got this problem resolved. it was nothing to do with the switching side. The problem was that there was a particular app on the user PC which whenn started used to kick the PC out of the network completely.
After the troubleshooting it was realised that the app could not work at 1G which the port was working at. The moment we turned it hard 100M, everything came back normal.
Anyway, thanks for your time in this.
Cheers!
Mohit
