Switching loop in Stack switch
anoop_mohan
Community Member
I have two 3560 switch which needs to be configure as a stack. will it form a swithing loop if i uplink each of those switches to a single core switch.if yes how to avoid it ?
Anoop,
Yes you would, it's the same as if you just connected 1 switch to 2 seperate core switches, this also would create a switch loop.
HTH>
5 Replies 5
andrew.prince
Level 11
Level 11
if you interlink the two 3560's via the stack cable - then become 1 logical switch, even though they are 2 physicals switches.
You can have multiple uplinks to your core switches, STP will recognise the switch stack as 1 logical switch - there will be no switching loop.
HTH>
Hi andrew,
Thank you very much for your response to my query.Could you also confirm if we need to run STP in switch stack as well?
thanks
Anoop M
Anoop,
HTH>
thanks
np - glad to help
