switching or routing between two switches?
Network Pro
hi,
i would like to know what is the best to use switching or routing in the following scenario:
SW A1 ----------SW A2
|            (Trunk)
SW B1-----------SW B2
Switch A!1 and Switch A2 are trunked (l2) and so as B1 and B2. assume both has its own set of vlans (say SW A1 and SW A2 has 100,101,102 and SW B1 and SW B2 has 200,201,202)
Now i know that we trunk sw a1 and swb2 or we can use routed link...
say if i do this:
on switch A1
int vlan 254
desc transit vlan to sw b
ip address 10.10.10.1
int gi0/1
switchport mode trunk
switchport access vlan 254
on switch B1
int vlan 254
desc transit vlan to sw A
ip address 10.10.10.2
int gi0/1
will the above work? if it does which is the best routed or this config ? what will be the difference ?
7 Replies 7
ALIAOF_
Level 6
Level 6
Are these L3 switches I am assuming?  Enable IP Routing and trunk the ports between SWA1 and SWB1 like you said, take out "switchport access vlan 254" and "interface vlan 254" command you don't need to create another VLAN.  Just a trunk between two switches is fine.  Make sure VLAN's from switch B are in switch A's database and vice versa.
thanks for this but i would like to use a dedicatiated vlan as transit vlan and hence the question
i know both these ports can be trunked instead of going through the above config but would like to know if you use a interface vlan and apply a port to that vlan will it work ? also is routing preferred to this method ?
You still would leave the port as trunk and not add the access command.  Here is a great article that will guide you:
http://packetlife.net/blog/2011/feb/9/hybrid-access-layer-design-revisited/
thanks but in order to use a vlan as transit vlan how do i do this ? basically i am trying to dedicate a vlan just for transit between two switches
Abzal
Level 7
Level 7
There are two options:
1. As Mohammad said you can configure them as a trunk port. And add vlans to switchA1/switchA2 200,201,202 and to switchB1/switchB2 100,101,102.
For redundancy:
Configure switchA1 STP primary root bridge for 100,101,102 vlans and secondary root bridge for 200,201,202 vlans.
Configure switchB1 STP primary root bridge for 200,201,202 vlans and secondary root bridge for 100,101,102 vlans. And connect switchA2 to switchB1, switchB2 to switchA1.
2. Or just configure ports between them as routed ports and EIGRP between them in order to exchange routes.
If you would use first option on large network there will be a lot of broadcasts. So I think it's better to use routed ports to eliminate broadcasts.
Best regards,
Abzal
ok thanks
but in which instance would you use the config below ? ( i have seen these on trunk ports)
int fa0
switchport access vlan998
switchport native vlan 998
As I said you can connect switchA1 and switchB1 each other and configure between them with command like above
native vlan need to be the same. No need switchport access vlan 998
SwitchA1
int g0/1
switchport trunk native vlan 998
SwitchB1
int g0/1
But make sure that native VLAN is on both switches database.
Please rate helpful posts.
Best regards,
Abzal
