Switching Tcam
Mlex1
Hello everyone i see this log on my stack switch 3750g, how i should solve this problem thanks in advance
%HARDWARE-1-TCAM_ERROR: Found error in HQATM TCAM Space and not able to recover the error
show platform tcam usage
TCAM Table
TCAM / SSRAM Table TCAM SSRAM
Start Size X Start Size Y
Local Forwarding Table: 0 1D40 1 0 1D40 4
Local Learning Table: 0 1D40 1 7500 1D40 2
Secondary Forwarding Table: 1880 D80 1 AF80 D80 8
QoS Table: 2600 1800 1 1E700 1800 4
ACL Table: 3E00 2000 1 24700 2000 4
IPV6 Secondary Forwarding Tabl 7D50 180 2 1E0C0 C0 8
IPV6 Classification Table: 7ED0 80 2 2C720 40 4
IPV6 ACL Table: 7F50 A0 2 2C820 50 4
Station Table: 0 0 0 2C980 1D40 4
MAC Address Table: 0 0 0 33E80 1800 8
Multicast Expansion Table: 0 0 0 3FE80 422 8
VLAN List Table: 0 0 0 43000 400 10
Equal Cost Route Table: 0 0 0 42000 80 20
X - Number of 144-bit TCAM entries per descriptor
Y - Number of bytes per descriptor
SDM template realignment scheme-1 in effect
show platform tcam utilization
CAM Utilization for ASIC# 0 Max Used
Masks/Values Masks/values
Unicast mac addresses: 784/6272 37/230
IPv4 IGMP groups + multicast routes: 152/1216 6/26
IPv4 unicast directly-connected routes: 784/6272 37/230
IPv4 unicast indirectly-connected routes: 280/2240 20/99
IPv4 policy based routing aces: 0/0 0/0
IPv4 qos aces: 768/768 410/410
IPv4 security aces: 1024/1024 51/51
Note: Allocation of TCAM entries per feature uses
a complex algorithm. The above information is meant
to provide an abstract view of the current TCAM utilization
show platform tcam errors
TCAM Memory Consistency Checker Errors
TCAM Space Values Masks Fixups Retries Failures
Unassigned 0 0 0 0 0
HFTM 0 0 0 0 0
HQATM 7 0 7 0 0
Wish all the best
Mark Elsen
   - FYI : https://community.cisco.com/t5/switching/found-error-in-hqatm-tcam-space-and-not-able-to-recover-the/m-p/1821157/highlight/true#M197421
  M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
9 Replies 9
Mlex1
read some articles, recommended reboot the stack switch, but it's last option in my situation
Wish all the best
Mark Elsen
  M.
       Beauty and terror
      Just keep going
       No feeling is final
Haha glad you're beautiful, but in your link i see only one solution reboot the stack, this option i will use last
Wish all the best
M02@rt37
Hello @Mlex1
What is the IOS version please ?
Do you use a particular sdm template ?
Best regards
> c3750-ipservicesk9-mz.150-2.SE11.bin
> default
Wish all the best
Mlex1
here i have some doubt maybe of this 7 mistake HQATM 7 0 7 0 0
HFTM 0 0 0 0 0
HQATM 7 0 7 0 0
Wish all the best
Mlex1
The error affects the receipt of the IP address? as some employees say that our Internet is not working, although before that everything was fine
Wish all the best
@Mlex1
Do you have in parallel, high cpu usage ?
Best regards
not
Wish all the best
