switchport access and switchport trunk
roger perkin
Level 2
Level 2
Can someone confirm my thoughts on this switchport configuration
interface FastEthernet0/5
description Mail-Server1
switchport access vlan 710
switchport mode trunk
It is my understanding that as this switchport is configured as a trunk the switchport access vlan 710 is a redundant line?
On the other end of the port is a router configured like this
interface GigabitEthernet0/1.1
encapsulation dot1Q 1 native
If someone can clear up my understanding on this before I remove the switchport access vlan 710 command as I dont' think it is doing anything
Roger
Jan Hrnko
Level 4
Level 4
Hi Roger,
the switchport can be either access or trunk.
You can write it in a manner as you did but as you enter the switchport mode trunk command the
switchport access vlan 710 is simply ignored till the time that you enter switchport mode access(which will rewrite switchport mode trunk command).
So
results in TRUNK (switchport access vlan 710 ignored).
What do you mean by redundant line? That if port is not negotiated it will work in access mode in vlan 710?
Best regards,
Jan
5 Replies 5
Jan Hrnko
Level 4
Level 4
Hi Roger,
So
Best regards,
Jan
That is what I thought, thank you for clarifying
I am tidying up a config on a 3560 and there is a lot of this!
Roger
Hi Roger,
yes It can be a little bit confusing because both commands will show up in running config. But it works as I said. You can verify this by issuing command
show interface XXX switchport
and check for Operational mode. It should be trunk.
Best regards,
Jan
How do Use no switchport cmd for c3640-ik9o3s-mz.124-25b.image
I will be very glad if you give me the solution
bellaichef
there is an easy way to make your port support both vlan710 in access mode and trunk mode:
Interface FastEthernet0/5
switchport trunk native vlan 710
This mean that all tagged frame will go through the trunk and all none tagged frame will go through vlan 710.
Bye
FB
