Difference between IE-3300 and IE-3400 Industrial ethernet switches
l.buschi
Level 2
Level 2
can anyone explain me the difference between IE-3300 and IE-3400 industrial ethernet switches?
Also, is IE-4000 serie going eos?
Tks
Johnny
Leo Laohoo
IE-3400 supports SD-Access.
I strongly recommend you talk to your respective Cisco AM/SE and ask them about the IE-9300.
IE-3400 is in serious competition with IE-9300 and one of them is going to have an EoL announcement soon.
Many tks,
I need 8-port HW upgradable rugged PoE+ switch for DIN guide.
I don't need any SD-access or feature other than simple ethernet PoE access in a compact DIN apparatus.
do you think IE-3300 will fit me and do you think IE-3300 is going eos?
tks again
Johnny
I cannot answer that question because nobody knows about your network other than you.
As far as I know, IE-9300 have already been released (with limited models).  As soon as the models which are "similar" to the IE-3300/IE-3400 comes out, IE-3300/IE-3400 EoS announcement is not far away.
