switchport block multicast
tedauction
Level 5
Level 5
Hello, as part of our normal switch build I notice these two commands are to be placed on every switch access port:
no ip igmp snooping tcn flood
Are these two commands really necessary or recommended as standard procedure to put on a switchport ?
We do use multicast traffic on our LAN for certain ports.
Thanks kindly for any advice.
Reza Sharifi
I think it is good idea to have these commands in your basic config.
Occasionally, unknown unicast or multicast traffic is flooded to a switch port because a MAC address has timed out or has not been learned by the switch. (This condition is especially undesirable for a private VLAN isolated port.) To guarantee that no unicast and multicast traffic is flooded to the port, use the switchport block unicast and switchport block multicast commands to enable flood blocking on the switch.
link:
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst4500/12-2/31sg/configuration/guide/conf/uniflood.html
With the no ip igmp snooping tcn flood command, you can disable multicast flooding on a switch interface following a topology change. Only the multicast groups that have been joined by a port are sent to that port, even during a topology change.
link:
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst4500/12-2/53SG/configuration/config/multi.html
Reza Sharifi
link:
link:
