Switchport bridge configuration for cisco 3750
cssam
hi,
I need to collect sniffer trace from MPLS link. Since it's directly from ISP to router ethernet.I am planning to put a cisco 3750 in between ISP and Router.
Having cisco 3750 in place, can i configure bridge port to bypass MPLS traffic and mirror the port?
Latchum Naidu
Hope the below examples will help you.
This example shows how to create bridge group 10, to specify that the VLAN-bridge STP runs in the
bridge group, to define a port as a routed port, and to assign the port to the bridge group:
Switch(config)# bridge 10 protocol vlan-bridge
Switch(config)# interface gigabitethernet3/0/1
Switch(config-if)# no switchport
Switch(config-if)# no shutdown
Switch(config-if)# bridge-group 10
This example shows how to create bridge group 10 and to specify that the VLAN-bridge STP runs in the
bridge group. It defines a port as an SVI and assigns this port to VLAN 2 and to the bridge group:
Switch(config)# vlan 2
Switch(config-vlan)# exit
Switch(config)# interface vlan 2
Switch(config-if)# exit
Switch(config)# interface gigabitethernet2/0/2
Switch(config-if)# switchport mode access
Switch(config-if)# switchport access vlan 2
Please rate the helpfull posts.
Naidu.
Julio Garcia
Im pretty sure you could just do a normal access vlan switch ports
turn off unnecessary stuff like cdp , and put on bdpu filter so you dont see unnecessary traffic
eg...
Int gi x/x
description One end of mpls connnection
switchport
switchport access vlan 500
spanning-tree portfast
spanning-tree bpdufilter enable
switchport nonegotiate
no cdp enable
Int gi x/x
description Other end of mpls connnection
switchport
no cdp enable
then do a span port on either port , doesnt matter which one
monitor session 1 source interface x
monitor session 1 destination interface x
destination interface , connect your laptop to this and run wireshark.
