Switchport goes down when moving from auto to 1000/Full
d-fillmore
Level 2
Level 2
Hi - I have got 2 3560s runnning 12.2(25)SEB4 connected to each other over 2 Gig TX links in a channel. Config of each is below;
Switch 01
interface GigabitEthernet0/47
description *** Etherchannel to Switch 02 ***
channel-group 1 mode auto
interface GigabitEthernet0/48
Switch 02
description *** Etherchannel to Switch 01 ***
channel-group 1 mode desirable
This works fine. However, if I then hard code Switch 01's speed and duplex to 1000/Full for port g0/47, and do the same on Switch 02, the link goes down. The port status says not connected. It remains like that even if I remove the channel-group config so the config is as follows;
Switch 01
duplex full
speed 1000
Switch 02
duplex full
speed 1000
Can anyone tell me the possible cause of this?
Many Thanks in advance
ankbhasi
Hi Friend,
When you just change the speed and suplex settings for one single port on port channel it brings an inconsistency in etherchannel configuration.
Etherchannel confiog guidelines says
Configure all ports in an EtherChannel to operate at the same speeds and duplex modes
Can you try changing the speed and duplex settings on all 4 ports?
Ankur
Amit Singh
All the ports in the channel have to be with the same config. All the ports settings related to speed/duplex,STP,trunking have to be eaxctly same on all the ports. If its not the switch detects it as a ether-channel mis-configuration and brings the channel down.
However, if you have removed the channel config, the link come up fine. What if you take the channel config out, set all the ports to auto and then hardcore the speed and duplex on the switchports.One of the port should go to STP blcoking mode as you are not running ether-channel config on the switches.
HTH,
-amit singh
Hi guys, thanks for your responses.
With all etherchannel configuration removed, the configs look like this;
Switch 01
description *** Etherchannel to Switch 02***
duplex full
speed 1000
duplex full
speed 1000
Switch 02
duplex full
speed 1000
At soon as the settings were hard coded on Switch 02's port g0/47, the port went down.
As the port is down (not connected) so spanning tree didn't shut it down.
I want to hard code the settings on Switch 02's port g0/48, but I am doing this remotely and accessing Switch 02 through Switch 01 so I run the risk of disconnecting the switch unless I do a scheduled reload which I don't think my customer will go for.
Any other ideas?
Cheers, Dom
