switchport port-security maximum
Rafael Jimenez
Level 7
Level 7
I have a 4510R switch, ((cat4500e-UNIVERSALK9-M), Version 03.05.02.E RELEASE SOFTWARE (fc1)).
I´m configuring the port-security maximum using the following commands:
switchport port-security maximum 1 vlan access
switchport port-security maximum 1 vlan voice
I dont know why some times this work, some times do not work.
to solve the issue I had to use the three commands:
switchport port-security maximum 2
the documentation do not say nothing about if I have to use the three commands together.
amikat
This is an excerpt from the Configuration Guide for your box and IOS-XE release:
Each VLAN can be configured with a maximum count that is greater than the value configured on the port. Also, the sum of the maximum configured values for all the VLANs can exceed the maximum configured for the port. In either of these situations, the number of MAC addresses secured on each VLAN is limited to the lesser of the VLAN configuration maximum and the port configuration maximum. Also, the number of addresses secured on the port across all VLANs cannot exceed a maximum that is configured on the port.
The default "switchport port-security maximum" value for the port is "1". So unless you change this value to "2" your port can sense max. 1 MAC address in either vlan "access" or "voice" ONLY without triggering violation. This means that the total maximum number of MAC addresses allowed  per all configured vlans per port equals ONE at the default only.
I hope my English makes sense.
Best regards,
Antonin
amikat
Best regards,
Antonin
