switchport priority extend cos 0
mahesh18
Level 6
Level 6
Hi all,
if we have cisco IP phone and it is connected to switch and
pc is connected  to the  IP phone and we have this config
interface fa0/1
mls qos trust cos
mls qos trust device cisco-phone
if someone can explain me what this command will do  switchport priority extend cos 0
1>to packets coming from pc to IP phone access port?
regards
mahesh
2 Accepted Solutions
jonathanaxford
Level 3
Level 3
Hi Mahesh,
The command you refer to will instruct the switch to remark any traffic received from the PC (Via the IP Phone)  with a CoS value of 0. I think this is the default value in most cases.
This is from the 2950 software config guide:
Overriding the CoS Priority of Incoming Data Frames
You can connect a PC or other data device to a Cisco 7960 IP Phone port.  The PC can generate packets with an assigned CoS value. You can  configure the switch to override the priority of frames arriving on the  IP phone port from connected devices.
Beginning in privileged EXEC mode, follow these steps to override the  CoS priority received from the nonvoice port on the Cisco 7960 IP Phone:
Command
Purpose
Step 1
configure terminal
Enter global configuration mode.
Step 2
interface interface-id
Enter interface configuration mode, and specify the interface connected to the IP phone.
Step 3
cos
value
Set the IP phone access port to override the priority received from the PC or the attached device.
The CoS value is a number from 0 to 7. Seven is the highest priority. The default is 0.
Step 4
end
Return to privileged EXEC mode.
Step 5
show interfaces interface-id switchport
Verify your entries.
Step 6
copy running-config startup-config
(Optional) Save your entries in the configuration file.
Hope this helps
Jonathan
to verify this command you have to do sh  interface XX switchport because this is default config and so won't appear in the running.
second when IP phone port receive the packet from pc the default cos 0 means that traffic is not given any priority right?
It means the original  L2 QoS marking of the traffic  is not trusted and reset to 0.
Regards.
Alain.
jonathanaxford
Level 3
Level 3
Hi Mahesh,
Command
Purpose
Step 1
configure terminal
Step 2
Step 3
cos
value
Step 4
end
Step 5
Step 6
Hope this helps
Jonathan
thanks for reply
i check the port config and it does not show the command
so as this is default config thats the reason it is not showing  up in running config?
regards
mahesh
Regards.
Alain.
Hi Alain and jonathan,
Many thanks for taking your time and explaining this to me.
regards
mahesh
