Switchport Utilization by VLAN on Cisco 4510
adrianportier
I'm trying to figure out the best way to pull switch port utilization within a specific VLAN on a switch. Example, finding the utilization on all ports assigned to VLAN 500. I've used "sh int stats" but that's at the hardware level and doesn't specifically call out just the ports on the specific VLAN. I know I can cross reference with the "show vlan id 500" command, but that's just time consuming. Any ideas are greatly appreciated.
Captain HoOmi
If you want to see only bandwith utilisation: SNMP
If you want to see detailed utilisation report ( with IP, port and aplication details) : Netflow
** Please rate this post or accept the solution if it helped! :) **
Deepak Kumar
You can use the Netflow which will give you must more information.
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
