SYN issue on Static NAT
srsiddiqui2007
I am having a SYN issues when configuring Static Route with NAT / PAT. Below configuration was working
absolutely fine till i added some more commands (BOLD ones) so that my other internal website
is accessible over internet. Whenever i try to access the website over internet i am getting
SYN error on Syslog.
access-list 201 extended permit ip any any
access-list 201 extended permit tcp any host (Public IP) eq https inactive
global (outside) 1 interface
nat (inside) 0 access-list inside_nat0_outbound
nat (inside) 1 10.10.1.0 255.255.255.0
nat (inside1) 1 192.168.3.51 255.255.255.255
static (inside1,outside) tcp interface www 192.168.3.32 www netmask 255.255.255.255
access-group 201 in interface outside
access-list 201 extended permit tcp any interface outside eq 4026
static (inside1,outside) tcp interface 4026 192.168.3.34 4026 netmask 255.255.255.255
Local4.Info     192.168.3.50     %ASA-6-302014: Teardown TCP connection 257819 for outside:
115.x.x.x/53208 to inside1:192.168.3.34/4026 duration 0:00:30 bytes 0 SYN Timeout
Local4.Info     192.168.3.50     %ASA-6-302013: Built inbound TCP connection 257820 for outside:
115.x.x.x/53225 (115.x.x.x/53225) to inside1:192.168.3.34/4026 (1.2.3.4/4026)
cadet alain
-have you tried from inside to this port ?
-does this server has a correct default route to reply ?
- isn't there any software firewall on this machine that could prevent communication ?
Regards.
Alain
Yes, the website is working fine from Inside LAN
yes, the default gateway of Server is 192.168.3.50 (inside1)
No software firewall enabled
