I am trying to upgrade my 9407R switch from version [Gilbraltar]16.12.03a to [Cupertino]17.9.5. However, my switch is dual-SUP. I'd like to synchronize the SUPs before upgrading, in order for both SUPs to hopefully cooperate more effectively. Could I use the following commands? Notably, these instructions are for a 4507 switch. I'll take any suggestions.
Copy the new Cisco IOS software image to bootflash or slot0 on both supervisor engines with these commands:
Configure the supervisor engines to boot the new image. Use these commands:
Switch#configure terminal
Switch(config)#config-register 0x2
Switch(config)#boot system flash device:file_name
Synchronize the supervisor engine configurations:
Switch(config)#redundancy
Switch(config-red)#main-cpu
Swicth(config-r-mc)#auto-syn standard
Issue the copy running-config start-config command to save the configuration.
Issue the redundancy reload peer command to reload the standby supervisor engine and bring the engine back online (with the new version of Cisco IOS software).
