SYS-2-MALLOCFAIL on WS-C2950G-48-EI
NetWorkkss
I have a problem, I can't to connect on my switch (WS-C2950G-48-EI) with Telnet or HTTP.
When to connect with console, i have a error :
SYS-2-MALLOCFAIL : Memory allocation of 10000 bytes failed from 0x801DBEE4, alignment 0
Pool: Processor Free: 968 Cause: Not enough free memory
Alternate Pool: I/0 Free: 69716 Cause: Memory fragmentation
How can I solve this problem ? a reboot ?
Leo Laohoo
Most likely an IOS bug.
A reboot can fix this issue.
glen.grant
Agree , sounds like a memory leak and a reboot will fix it .  If the code is old , upgrade while you are at it.
adanealemayehu
Thats a memory leak and your device needs to be power cycled
NetWorkkss
The reboot has solved my problem.
Thank you for help
