Syslog Filtering
alexander.bauer
Community Member
Hello, I would like to filter the following messages and save on a syslog server.
I think I can use the discriminator command.
HSRP - status change
OSPF - neighbor change
BGP - Peer Change
STP topology and root change
Can you help me how to do this?
Thank you very much
Mark Malone
Yes if you want to filter your messages going to the syslog server you can use logging discriminator but you need the alert you see in logs , check this guide its a good quick example of how to set it up for the logs you want
https://mrncciew.com/2013/07/27/suppress-a-syslog-msg/
Mark Malone
