Problem with switchport voice vlan
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
12-15-2016 02:36 AM - edited 03-08-2019 08:35 AM
I have a problem with command :
Switch(config-if)#switchport mode access
Switch(config-if)#switchport voice vlan <Voice VLAN ID>
Switch(config-if)#switchport access vlan <VLAN ID>
"Switchport voice vlan" is not recognized. My switch is the SG500-28P.
This the print of show running connfig :
config-file-header
switche64d9a
v1.4.5.02 / R800_NIK_1_4_194_194
CLI v1.0
set system mode switch queues-mode 4
file SSD indicator encrypted
ssd-control-start
ssd config
ssd file passphrase control unrestricted
no ssd file integrity control
ssd-control-end cb0a3fdb1f3a1af4e4430033719968c0
vlan database
vlan 5,10,20,30,100,200
exit
voice vlan id 20
voice vlan cos 5
voice vlan oui-table add 0001e3 Siemens_AG_phone________
voice vlan oui-table add 00036b Cisco_phone_____________
voice vlan oui-table add 00096e Avaya___________________
voice vlan oui-table add 000fe2 H3C_Aolynk______________
voice vlan oui-table add 0060b9 Philips_and_NEC_AG_phone
voice vlan oui-table add 00d01e Pingtel_phone___________
voice vlan oui-table add 00e075 Polycom/Veritel_phone___
voice vlan oui-table add 00e0bb 3Com_phone______________
hostname switche64d9a
no passwords complexity enable
username cisco password encrypted 7af78c911d5b48bea1dc2449d9d89513abeb4be5 privilege 15
ip ssh server
ip telnet server
interface vlan 200
ip address 192.168.200.4 255.255.255.0
no ip address dhcp
interface gigabitethernet1/1/1
spanning-tree link-type point-to-point
switchport trunk allowed vlan add 5,10,20,30,100,200
macro description switch
!next command is internal.
macro auto smartport dynamic_type switch
interface gigabitethernet1/1/2
switchport access vlan 5
voice vlan cos mode all
interface gigabitethernet1/1/3
switchport access vlan 20
- Labels:
LAN Switching
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
12-15-2016 03:54 AM
that command is not supported on SMB switches
This is how you enable the voice vlan through the GUI
https://supportforums.cisco.com/video/12305226/sg500-series-switch-auto-voice-vlan-configuration-qos
Not sure about cli commands starting at page 264 goes through how to set it up in the admin guide too through GUI
http://www.cisco.com/c/dam/en/us/td/docs/switches/lan/csbms/Sx500/administration_guide/500_Series_Admin_Guide.pdf
