syslog message and logging command
sarahr202
Level 7
Level 7
Hi everybody.
logging buffered 4096 warnings
The above causes router to log all the events with severity level 4 or below in buffer.
What about logging console warnings  command?
will the above command  cause router to send log messages with severity level 4( warnings severity level) to console only or will the router send all the log
messages with severity level 4 or below to console ?
thanks and have  a great weekend.
2 Accepted Solutions
Reza Sharifi
Hi Sarah
Yes, it is up to that level:
The
logging console
command  limits the logging messages displayed on the console terminal to  messages up to and including the specified severity level, which is  specified by the
level
argument.
Reza
Reza Sharifi
Hi Sarah,
Here are the results for a switch
Switch(config)#logging console warnings
Switch(config)#do sh run | inc logging
Switch(config)#logging console notifications
Switch(config)#
As you can see when the switch is configured with level-4 (warning) it only shows that and up to it.  When it is changed to level 5 (notifications) than it only show notification and what ever under it.
Reza
Reza Sharifi
Hi Sarah
The
logging console
level
argument.
Reza
Reza Sharifi
Hi Sarah,
Switch(config)#
Reza
thanks Reza
