System not accessible with Sub Interface configured on router
joseph.a1
We had configured sub interfaces on our router to connect our local lan, fa 0/1.7, fa 0/1.8, After that we had configured vlans like vlan 7 & 8 on L2 switch. Network is working properly, when I am trying to ping from vlan 7 to vlan 8, then I am getting the icmp reply. But when I am trying to access the computer to transfer the file then its not working.
interface fastethernet0
 description ** WAN INTERAFCE **
 ip address 10.250.90.249 255.255.255.252
 duplex full
 no ip redirects
 no ip proxy-arp
 exit
interface fastethernet1
 description ** LAN INTERFACE **
 no ip redirects
 no ip proxy-arp
 exit
interface fastethernet1.7
 ip address 192.168.7.1 255.255.255.0
 encapsulation dot1q 7
 exit
interface fastethernet1.8
 ip address 192.168.8.1 255.255.255.0
 encapsulation dot1q 8
 exit
interface fastethernet1.9
 ip address 192.168.9.1 255.255.255.0
 encapsulation dot1q 9
 exit
interface serial0/0
 physical-layer sync
 encapsulation hdlc
 exit
interface serial0
 physical-layer sync
 encapsulation hdlc
 exit
interface null0
 exit
ip route 0.0.0.0 0.0.0.0 10.250.90.250
line con 0
 exec-timeout 5 0
 login local
line vty 0 4
 exec-timeout 5 0
 login local
 exit
logging console critical
ip dhcp excluded-address 192.168.7.1 192.168.7.30
ip dhcp excluded-address 192.168.8.1 192.168.8.30
ip dhcp excluded-address 192.168.9.1 192.168.9.30
ip dhcp pool GRDFLR
 network 192.168.7.0 255.255.255.0
 default-router 192.168.7.1
 dns-server 192.1.5.31
 domain-name earth.local
 exit
ip dhcp pool FIRSTFLR
 network 192.168.8.0 255.255.255.0
 default-router 192.168.8.1
 exit
ip dhcp pool SCNDFLR
 network 192.168.9.0 255.255.255.0
 default-router 192.168.9.1
 exit
ntp server 10.250.90.245
Guys please guide for this issue.
No access-list configured on the router
Thanks & Regards,
Joseph Asvin
Jon Marshall
Joseph
We need a bit more information.
What computer are you trying to access, from where etc.
Jon
Dear Jon
I am not able to access from any version of computer from 7 Vlan to 8/9 Vlan, vise versa
