systemd[1]: Failed to start Set System Clock From RTC.
Hello everyone,
I have a problem on my switch (3650-24ps-l ).the switch is in  rommon mode(switch:)
I tried to repair it by implementing a new image, but I have the following problem:
switch: flash_init
Initializing Flash...
flashfs[7]: 0 files, 1 directories
flashfs[7]: 0 orphaned files, 0 orphaned directories
flashfs[7]: Total bytes: 6784000
flashfs[7]: Bytes used: 1024
flashfs[7]: Bytes available: 6782976
flashfs[7]: flashfs fsck took 2 seconds....done Initializing Flash.
switch: dir
List of filesystems currently registered:
xmodem[0]: (read-only)
null[1]: (read-write)
bs[3]: (read-only)
usbflash0[10]: (read-write)
flash[19]: (read-only)
tftp[20]: (read-write)
switch: dir usbflash0:
Directory of usbflash0:/
4 -rw- 404622964 cat3k_caa-universalk9.16.06.05.SPA.bin
5 -rw- 79122052 cat3k_caa-base.SPA.03.03.05SE.pkg
6 -rw- 302988468 cat3k_caa-universalk9.SPA.03.06.04.E.152-2.E4.bin
7 -rw- 303772864 cat3k_caa-universalk9.SPA.03.06.06.E.152-2.E6.bin
8 -rw- 640316 cat3k_caa-universalk9.16.06.04.CSCvk71349.SPA.smu.bin
9 -rw- 345404 cat3k_caa-universalk9.16.06.04.CSCvk02589.SPA.smu.bin
10 -rw- 257651868 WS-C3850-24T_cat3k_caa-universalk9.SPA.03.03.05.SE.150-1.EZ5.bin
11 -rw- 328618032 cat3k_caa-universalk9.SPA.03.07.05.E.152-3.E5.bin
2337783808 bytes available (1677795328 bytes used)
switch: boot usbflash0:/cat3k_caa-universalk9.16.06.05.SPA.bin
Reading full image into memory.....................................................................................................................................................................................................................................................................................................................................................................................................done
Bundle Image
Kernel Address : 0x54eec6d4
Kernel Size : 0x365d89/3562889
Initramfs Address : 0x5525245d
Initramfs Size : 0x16ddecc/23977676
Compression Format: mzip
Bootable image at @ ram:0x54eec6d4
Bootable image segment 0 address range [0x81100000, 0x81bffb30] is in range [0x80180000, 0x90000000].
File "usbflash0:/cat3k_caa-universalk9.16.06.05.SPA.bin" uncompressed and installed, entry point: 0x816e0330
Loading Linux kernel with entry point 0x816e0330 ...
Bootloader: Done loading app on core_mask: 0xf
### Launching Linux Kernel (flags = 0x5)
Can you help me please
Mark Elsen
 - Try a factory defaults reset ; if the problem persists afterwards I think the switch is toast.
M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
can you tell me how to do it?
 - Please feel free to google on this on the particular topic, for your model : I presume you will find the answer quickly.
M.
       Beauty and terror
      Just keep going
       No feeling is final
