Tacacs+ authentication and authorization fail with NXOS and ACS 5.3
Thibault BRISSE
I am trying to configure TACACS+ authentication and authorization for NX-OS (Nexus 7010) with Cisco ACS 5.3.
Configuration on Nexus's are the following :
feature tacacs+
tacacs-server host 10.16.6.3 key 0 UE9Pp40o
tacacs-server host 10.16.6.4 key 0 UE9Pp40o
ip tacacs source-interface vlan 99
aaa group server tacacs+ TACACS_SERVER
server 10.16.6.3
server 10.16.6.4
aaa authentication login default group TACACS_SERVER
aaa authorization commands default group TACACS_SERVER
aaa authorization config-commands default group TACACS_SERVER
aaa authentication login console group TACACS_SERVER
aaa accounting default group TACACS_SERVER
aaa authentication login error-enable
I configured ACS for authorization on this way :
This configuration doesn't work, I have the following message :
Error: AAA authorization failed AAA_AUTHOR_STATUS_METHOD=17(0x11)
Do you have an idea ?
Thank you in advance,
Thibault
5 Replies 5
zartar911
Hi Thibault,
Use the following attribute for nexus
Tim
Hi Zartar,
With your configuration I have exactly the same error output :
Thibault
Hi everybody,
I create an SR, Cisco openened a Webex session and at the moment they don't succeed to operate NX-OS role with ACS.
However, they added a "command set" with permit all shell commands and now authorization work.
I will keep you informed.
Thank you,
Thibault
Any luck with the command set that cisco gave you. I'am having the same problem you are with my nexus 7010 and it is driving me nuts what needs to be set on the ACS for this to work.
Neal Gravatt
it worked for me.  I am using ACS v5.3 and nexus running code v5.1.3
