Tacacs Authorizationm with Cisco 1300 Switch
Have tried configuring Tacacs on a new Cisco 1300 switch, which is running on latest version.
Wherein Authentication is successful and able to access switch CLI but unable to see Authorization getting enforced on switch. Hvae checked ISE logs it shows authorization has been succeeded but not able to see any command set matched. In same policy other catalyst switches works as expected.
Has anyone come across same issue as in documentation also mentioned only about Authentication and no where its mentioned about Authorization hence not sure whether it will work or not.
0 Replies 0
