Tacacs on Nexus 5000
CAn you please help with the following
I have the following config on Nexus 5596
ip tacacs source-interface mgmt0
tacacs-server host 10.21.1.180 key 7 "xxxxxxi"
aaa group server tacacs+ Harrods-Switches
    server 10.21.1.180
tacacs-server directed-request
aaa authentication login default group Harrods-Switches
aaa authorization config-commands default group Harrods-Switches
After applying the config above when I try adding or removing any command from the Switch I get the following message
I can only run show command on my switch
Error: AAA authorization failed AAA_AUTHOR_STATUS_METHOD=17(0x11)
Is there any way I can revert the change made
Any help is much appreciated
mages_mark
You should still be able to login via console with the local username / password.... as long as you didn't remove the
aaa authentication login console local
The Nexi have some pretty handy aaa testing commands once you get consoled back in...
switch# test aaa server tacacs+ 10.10.1.1 user1 Ur2Gd2BH
switch# test aaa group TacGroup user2 As3He3CI
switch# test aaa auth command-type config-commands user XXXX command config
Hi Mark,
Many Thanks for your reply
I can logon using SSH and console but can not run any command in Global configration mode
I think the command below is causing this and I can not remove this command
When I look at the logs on ACS the authentication is failing
All,
Rebooted the ACS server which has fixed the problem I had.
Many Thanks for your help
