TACM ERROR messages 2960X
switch 2960x
TCAM region 24 error: move failed, source index 4828 target index 4829.
My Cisco switch 2960x run layer 3 warning error
 system messages -critical Description: TCAM region 24 error: move failed, source index 4828 target index 4829.
is there  any other way to fix this issue without rebooting the switch ?
Reza Sharifi
It appears that reboot is the only solution (according to the documentation).
https://www.cisco.com/c/en/us/td/docs/ios/system/messages/guide/sm_cn10.html
I am in total agreement with  @Reza Sharifi  you definitely need to restart the device in order to resolve the issue , note that it may end up being a temporary fix as the issue may re-appear in the close future.
Schedule a time to for a manual reboot or use the reload in hhh:mm  feature, this way you can schedule the device to reboot midnight or so.
P.Williams
