Tagged vs untagged traffic on cisco 3560 simple question
AdmIT
 I'm a newbie to Cisco switches, on previous ones my config would be simple:
port 1 -> router (tagged traffic for vlan 2,3, maybe untagged for mgmt vlan to access the switch)
ports 10-20 -> untagged traffic for vlan 2
ports 21-24 -> untagged traffic for vlan 3
and that's it.
Here, to make a tagged port on my 3560 as far as I understood I need to:
conf t
interface gi0/x
switchport mode trunk
switchport access vlan x ??
when I do:
show interface gi0/x switchport  I see:
Switchport: Enabled
Administrative Mode: trunk
Operational Mode: trunk
Access Mode VLAN: x (xxxx)
Trunking Native Mode VLAN: 1 (default)
On untagged I do:
switchport mode access
and I think that the untagged one should be correct :)
 To tag a vlan I need to add it to a trunking native mode vlan or access mode vlan?
Thank you in advance for any responses!
Reza Sharifi
Are you using one vlan for all these devices?
for trunk all you need is this:
conf t
interface gi0/x
If you want to be specific you can add the vlans to your trunk port
switchport trunk allowed vlan x,x,x
For access port your config is correct
On untagged I do:
Reza Sharifi
conf t
interface gi0/x
On untagged I do:
 Thanks for the response, I didn't notice "trunk allowed VLANs" :). In this particular case, I'm using only two VLANs which are tagged to separate routers as there are two WAN connections which had to be separated this way, that's why I wanted to specify which VLAN should be tagged to a specific port.
There should be command under the interface that is trunked. Here is an example.
Also if you are using older software you may have to set the encapsulation. See link:
switchport trunk allowed vlan  2, 10
or
switchport trunk allowed vlan  add 2, 10
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3560/software/release/12-2_55_se/configuration/guide/3560_scg/swvlan.html
