11-10-2013 08:59 PM - edited 03-07-2019 04:31 PM
The Root bridge acknowledges the TCN by sending configuration BPDUs with TCA bit set.
Before to it the designated bridge will acknowledge the bridge that generated a TCN because the bridge that identified the topology change will continue to send TCN until it gets acknowledgement.
Q. As an acknowledgment, what type of BPDU will the designated bridge send to the bridge that identified toplogy change ?
Is it the same BPDU as root bridge sends ?
Chandu
Solved! Go to Solution.
11-10-2013 09:50 PM
Hi Chandu,
The designated bridge acknowledges the TCN by immediately sending back a normal configuration BPDU with the topology change acknowledgement (TCA) bit set
Hope it helps!!
Karthick Murugan
CCIE#39285
11-10-2013 09:50 PM
Hi Chandu,
Hope it helps!!
Karthick Murugan
CCIE#39285
11-10-2013 09:55 PM
You can refer to the below CISCO document that explains the same.
http://www.cisco.com/en/US/tech/tk389/tk621/technologies_tech_note09186a0080094797.shtml
Karthick Murugan
CCIE#39285
