TCN counters
arunas.usonis
Does anyone know a command to reset STP TCN counters ? Have tried clear spann counters but didn't help
Arunas
rsimoni
Hi Arunas,
there is no such command. You need to either reload the switch or disable spanning-tree and re-enable it (but I would not do that).
Riccardo
