Dot1q tunneling on a Cisco 2960C
Hi!,
Does anyone know if its possible to do dot1q-tunneling on the new Cisco Calalyst 2960 Compact series switches? I know that the 3560 series support it, but im unable to find any information about the 2960C series, personally i doubt it as the standard 2960 series don't support it.
Thanks!
Daniel
Peter Paluch
Hello Daniel,
My personal opinion is the same as yours - the regular 2960 do not support the Q-in-Q Tunneling and I strongly doubt that this SP technology would be added to 2960C switches.
You can use the Feature Navigator at http://cisco.com/go/fn to check for yourself.
Best regards,
Peter
Hello Peter,
Thanks for the reply.
Aye, I checked the Feature Navigator, but there are several C2960 availiable but no C-series. As there are several 2960 availiable logic states that a C2960C would be as well its not the first time the feature navigator isn't updated.
Hopefully some helpful soul will login to their switch a do a check
Best regards
Daniel
