10-07-2013 01:44 PM - edited 03-07-2019 03:53 PM
Hello:
A few days ago I noticed a team CAT6509 that the processor was increasing and to give the command.
Processes show cpu sort
The process that more time was consumed in the syslog, and it disabled and under the cpu.
The question is I can enable TCP syslog, I assume this to be the syslog udp paralemos can open several roads, and it would be better if you only open a TCP connection.
It is my hypothesis, I hope and I can corroborate with their experiences.
10-07-2013 03:31 PM
Hola Jhoni.
If understand correctly you are saying that a 6k was having high cpu utilization caused by syslog process.. and then I don't understand what you meant, if you speak spanish I also do, I would be happy to help you with your concern.
Regards.
Wilson B.
10-07-2013 03:52 PM
Hola Wilson:
Efectivamente un CAT6509 estaba elevando su CPU y cuando di el comando:
show processes cpu sort
El proceso que estaba mas alto era el syslog, procedi a deshabilitarlo y el CPU bajo.
A raiz de esto quisiera poder habilitar el syslog via TCP en lugar de UDP, en base a la hipotesis de que el ser UDP el envio del syslog haya podido abrir conexiones paralelas y aumentado el proceso del CPU.
Muchas Gracias, por tus comentarios.
Saludos,
10-07-2013 04:11 PM
Saludos Jhoni.
Con el sgte comando usted podra hacer que syslog utilice TCP.
F340.22.22-6500-3(config)#logging host 1.1.1.1 transport tcp
Por defecto se utilizara puerto TCP 601, pero puede ser modificado con las variables que le muestro acontinuacion:
F340.22.22-6500-3(config)#logging host 1.1.1.1 transport tcp ?
audit Set this host for IOS firewall audit logging
discriminator Specify a message discriminator indentifier for this
logging session
filtered Enable filtered logging
port Specify the TCP port number (default=601)
sequence-num-session Include session sequence number tag in syslog message
session-id Specify syslog message session ID tagging
xml Enable logging in XML
Si tiene alguna otra pregunta no dude en hacerla.
Wilson B.
